2005 HCH Fuel Pump relay location, doesn't match diagrams/photos
I am trying to replace the fuel pump relay (Beck/Arnley Relay 12V 90080-87009 156700-0930) on my friend's 2005 Honda Civic Hybrid 1.3l.
I know it's supposed to be behind the glovebox, but the layout does not look like any photo or diagram I have seen of that area. Instead of four relays in a row with the blue FP relay on the left like 口口口口, I have four relays in a square like 田 . None of these are blue, and all have four pins instead of the five pins on the part I'm looking at. I have checked the other three(?!?!) fuse/relay boxes on the car, and found ONE similar relay under the hood with the same pin pattern, but a different size and numbered 156700-1200 instead of -0930. It was labeled with an engine icon.
I was hoping this would be an easy fix/rule-out for his intermittent hot starting problem...
Jcgbeasttube
Honda Civic (2006 - 2015)
Mar 19, 2018 10:07 PM
