Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
HRV - 2015 Car sits in garage for 1o days
Old Feb 28, 2018 | 04:33 AM
little Mary's Avatar
Default HRV - 2015 Car sits in garage for 1o days
My car battery dies after sitting for 10 days
This happen last month (Jan) and now Feb
Dealer said all was ok and was due to normal sitting .....unless I drive it every 2 - 3 days to keep it charged it should be ok......
I have never had this problem and being a senior makes me very nervous I will get stuck some where .....can you advise me...
thanks MJ
Old Feb 28, 2018 | 05:04 AM
1991civiclx13's Avatar
Default Re: HRV - 2015 Car sits in garage for 1o days
if the car sits for a while it does happen.
you could always go out and start it every couple days, or invest in a battery tender to keep the battery charged.
happened to me this winter with one of my vehicles... now i try to take it out for a drive/ or start it at least once a week
Old Feb 28, 2018 | 05:44 AM
Thank you, but I could not go out to start it because I had the flu then back surgery
but I will try to go out and start it when I am feeling better.......this has never happened
to me on all my other cars.....Regards MJ
Old Feb 28, 2018 | 05:47 AM
CandyRedRC46's Avatar
You should do a current draw test. Locate the circuit that has the high draw and confirm if within or out of spec. Then you have two choices
a. fix the circuit, if possible
b. remove the fuse, if possible or just while not in use.
rawsx
Mar 10, 2008 10:41 AM
snzh22
Nov 13, 2006 01:46 PM
SOKDO
Jun 2, 2005 10:33 AM
YellowGiser
Oct 9, 2003 10:48 AM
