Honda CR-V & Element 2WD & 4WD Element & CR-V
Gen 1 CRv - can i use RTV silicone as a sump gasket replacement?
Old Feb 27, 2018 | 02:12 AM
B20Zer's Avatar
Default Gen 1 CRv - can i use RTV silicone as a sump gasket replacement?
On a Gen 1 CRv can I use RTV silicone as a sump gasket replacement, ie no sump gasket just use Permatex rtv silicone to refit the sump?
The sump gasket is hellishly expensive locally $50 and I've seen some vehicles where even the factory will spec rtv as a suitable replacement for the sump gasket.
Old Feb 27, 2018 | 02:55 AM
UK-Kev's Avatar
Default Re: Gen 1 CRv - can i use RTV silicone as a sump gasket replacement?
The silicone spreads out both internally and externally and does not react well with the additives in the oil ….. You risk some of the silicone blocking up the oil galleries within the engine leading engine frailer.
Old Feb 27, 2018 | 04:19 AM
B20Zer's Avatar
If you slap it on like peanut butter then yes but careful application of the RTV is from all accounts fine, Honda even specs RTV to be applied with the sump gasket so they are't worried about it being used.
I remember with Toyota's I've had the Toyota dealer stopped carrying the sump gasket on some models because the factory rather specc'd RTV as the offical factory replacement, it must be safe if you do it correctly.
Old Feb 28, 2018 | 08:29 AM
UK-Kev's Avatar
Yes the approved installation of the sump is to use a 1/8 inch bead RTV only and wipe of any excess.
Old Feb 28, 2018 | 08:52 AM
B20Zer's Avatar
Old Feb 28, 2018 | 09:17 PM
SpiderX1016's Avatar
You'll be fine. Just use the grey RTV (Hondabond, Permatex Right Stuff, etc.).
Old Mar 1, 2018 | 06:37 AM
UK-Kev's Avatar
Yes I was confirming you are correct, why the questions marks!!!!
ezza
Nov 5, 2009 02:27 PM
85
Honda Motorcycles
11
Jul 2, 2007 03:19 AM
twenty
Jun 14, 2005 09:43 PM
Btothe3rdDegree
Aug 20, 2003 06:26 PM
B20-T
Feb 16, 2003 05:44 PM
