Will mechanical timing effect smog results? d16a6
Old Feb 23, 2018 | 12:09 PM
acmoc's Avatar
Default Will mechanical timing effect smog results? d16a6
Hi, I have a sohc.
I set the am timing like the d16a6, pointed at the rear t belt cover pointer, not the "up" and the crank at tdc.
Anyway, will my emmisions go down any if I set the cam to the "up position?
ignition timing will stay at 18 btd +- 2
Old Feb 26, 2018 | 06:46 PM
v4lu3s's Avatar
RTFM
Default Re: Will mechanical timing effect smog results? d16a6
it needs to be set to stock for stock emissions. that means mechanical timing and ignition timing. if it is not meeting emissions like that then you need to look at other things.
perry9251
Feb 21, 2018 07:58 PM
Dazer 1991
Aug 15, 2012 07:09 AM
supabang
Aug 3, 2007 10:54 PM
dsCRXsi
May 2, 2004 04:32 AM
B2FiNiTY
Jul 25, 2003 07:46 PM
