Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2004 Honda civic Coupe LX Check Engine P0134
Old Feb 19, 2018 | 03:13 PM
civiclx2004's Avatar
Default 2004 Honda civic Coupe LX Check Engine P0134
Hi Guys:
So I have a 2004 Honda Civic Coupe LX with 130K miles on it. My exhaust manifold was cracked so a friend of mine changed it and I also replaced both oxygen sensors. The exhaust manifold with Catalytic converter was a Dorman brand and the oxygen sensors were made by NTK. After driving for a few days with the new stuff I noticed my car struggling/hesitating while accelerating. The codes were P0135 and P0134. Upon further review, it seems like my upstream oxygen sensor NTK 24425 was only an oxygen sensor, but not an air-fuel oxygen sensor. So I got an upstream Denso 234-9005 air fuel ratio oxygen sensor and the hesitation is gone and the car runs smooth. However, the P0134 (bank 1 sensor 1, no activity) check engine light is still on. I cleared the engine light with the OBD2 scanner numerous times and still no luck. I replaced the ECM fuse under the hood and replaced the Air fuel relay fuse under the dash, but still no luck (all the fuses I replaced were working fine). After clearing the check engine light and starting the car the light comes on within 2 minutes. A friend of mine with help me do the continuity testing to see if there is no issue with the wiring, but I don't think that will be the issue.
I'm afraid it is the ECM/PCM.
I read here that there may be a PCM software update? (https://repairpal.com/pcm-software-u...ensor-code-346). Has anyone else done this?
Any help would be greatly appreciated since I have my Emissions test in a few months and I want to fix this problem. I searched online, but can't seem to find a solution to my problem. Thank you!
Old Feb 19, 2018 | 06:04 PM
toyomatt84's Avatar
Sanji
Default Re: 2004 Honda civic Coupe LX Check Engine P0134
Are you sure that the catalytic converter isn't blown out?
Old Feb 20, 2018 | 04:08 AM
I don't think the catalytic converter is the problem. I forget to add that since the catalytic converter and the exhaust manifold were together, when my friend changed the exhaust manifold, it was replaced with the Dorman 674-608 exhaust manifold with the catalytic converter.
Old Feb 20, 2018 | 09:06 PM
toyomatt84's Avatar
Sanji
No, you mentioned that... however, Dorman is a cheap part manufacturer and has been known to have issues from time-to-time with the quality of their products. I was just checking to see if it didn't arrive faulty, or fail early on.
Old Feb 21, 2018 | 04:51 AM
It did not cross my mind that the catalytic converter could be the problem. I have the exhaust manifold w/catalytic converter installed for almost 2 months now and have not noticed any issues. Plus don't you think if the catalytic converter was problem I would get another code besides P0134? This P0134 code is driving me insane. Thanks!
Old Feb 21, 2018 | 06:03 PM
holmesnmanny's Avatar
put the old sensors back in and clear the codes and see if it goes away
Old Feb 21, 2018 | 06:16 PM
I wish I had the old sensors. Being an idiot I threw them away thinking I will not need them.
Old Feb 22, 2018 | 12:40 PM
JPat's Avatar
How much was the manifold? Iam only asking because they are 800$ around here
I have never had luck with anything beside honda brand sensors
Old Feb 23, 2018 | 06:57 AM
The manifold with catalytic converter was $275. The $800 seems quite high. I know California has stringent emissions standards so those may run around ~$400 or higher.
I may need to buy the original Honda oxygen sensor.
Old Feb 23, 2018 | 05:39 PM
toyomatt84's Avatar
Sanji
The factory manifold/catalytic converter lists for $658 from Honda. $800 is a little overpriced, but not extraordinarily high. You paid very little for yours, and it may be reflected in the quality of the product received.
Old Feb 24, 2018 | 11:32 PM
seafoam it and look for white smoking leaking out somewhere
Old Feb 25, 2018 | 01:44 AM
JPat's Avatar
Thats retarded
Old Mar 24, 2018 | 04:04 PM
Hey Guys so an update.
After having bad luck with the Denso oxygen sensor I was left with two choices: buy the original honda air fuel upstream oxygen sensor or replace the ecm/pcm. I decided to buy the honda oxygen sensor (part #: 36531-plm-306) and the check engine light never came on. I have now driven over 500 miles and no check engine light! Great success!
Old Mar 24, 2018 | 05:31 PM
Thats retarded
not at all
mercedes227
Dec 18, 2017 04:13 PM
skitzo7170
Jan 1, 2016 03:49 PM
remi700
Jun 15, 2013 10:36 AM
t0pdogg
10
Oct 5, 2005 07:57 PM
M104-AMG
Mar 9, 2004 09:35 PM
