Accord ex manual transmission
Old Feb 18, 2018 | 08:42 AM
Joseph Ramirez's Avatar
Default Accord ex manual transmission
I have an accord ex 94 I changed my starter the clutch relay and took my main relay off but it looked good and my car still won't start any help please
Old Feb 18, 2018 | 09:12 AM
Teens10's Avatar
Default Re: Accord ex manual transmission
If you have a DMM, i would make sure your starter is getting everything it needs first of all ( power, ground, and signal). its grounded to the trans casing so if its dirty in that area you might have gotten some dirt between the starter and the casing so i would also double check that.
Old Feb 18, 2018 | 09:18 AM
It's clean plus I had a friend of mine that was a mechanic test my battery starter and my fuses under the hood and inside the car. I took the main relay out today it looked good but still may be no good when I turn my key the car won't even kick over
Old Feb 18, 2018 | 10:17 PM
holmesnmanny's Avatar
check if the clutch switch stop piece broke off at the pedal
wwolf771177
Jul 2, 2016 08:46 AM
Din
Jun 27, 2011 11:18 AM
ejvtec
Jun 16, 2011 05:21 PM
killerkali420
Mar 30, 2011 04:29 PM
stamen
Oct 10, 2007 08:31 PM
