Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
AC Compressor Growl. How likely is it that my system is contaminated?
Old Feb 17, 2018 | 09:33 AM
skshow289's Avatar
Default AC Compressor Growl. How likely is it that my system is contaminated?
I have a 2007 Honda Civic LX. The AC compressor makes a growling noise when engaged but still makes cold air just fine like it always has. I am certain the sound is coming from the AC compressor only and not from a blower motor or any other component on the vehicle. I have the mechanical aptitude to replace the compressor, put a vacuum on the system, check for leaks with manifold gauges, and recharge the system after the compressor is replaced. What I want to know is how likely is it that my AC system has been contaminated by my failing compressor (requiring changing of more than just the compressor and possibly the drier)? Like I said, the AC system still works and makes cold air perfectly, the compressor just growls.
Old Feb 17, 2018 | 01:12 PM
holmesnmanny's Avatar
Default Re: AC Compressor Growl. How likely is it that my system is contaminated?
are you sure it's not just the pulley bearing ?
if youre sure its internal, you will need to swap out the condenser as well as the drier, which is always on the replace list when opening the system
threeoten
Honda Civic (2001 - 2005)
Aug 10, 2016 08:31 PM
Underlook
Jul 14, 2013 06:05 PM
marqoid
10
Jun 28, 2013 04:41 PM
Turbo E
Aug 8, 2006 08:59 AM
vietnogi
May 24, 2005 08:01 AM
