1998 accord squeals while driving
Old Feb 13, 2018 | 09:41 AM
erogers5's Avatar
Default 1998 accord squeals while driving
Hello all, i have a 98 coupe 4 cylinder 5 speed MT. Ive noticed just today that when i hit first gear i start to get a somewhat quite constant squeak while in gear. as soon as i drop to neutral it stops, i rev it and nothing happens. It seems only when im in gear and moving. It sounds like a pulley, but my belt is tight and the pulleys all seem solid. I know shes old but does anyone have any idea? thank you
Old Feb 13, 2018 | 10:04 AM
holmesnmanny's Avatar
Default Re: 1998 accord squeals while driving
one of the belts could just be worn
Old Feb 13, 2018 | 12:22 PM
MAD_MIKE's Avatar
MM Gruppe B
If the squeal is predictable enough, open hood and use WD40 on the belts.
Go for normal drive.
If the squeal is still there, most likely not the belts.
WD40 is a solvent, not a lubricant, it will not harm the belts.
PhoRiuH
Transmission & Drivetrain
May 31, 2011 12:38 PM
NicoleAlexis
Jul 4, 2006 04:35 PM
randumb
Jan 20, 2006 07:32 PM
keepnsane
May 27, 2005 01:16 PM
