NGK Wires and OEM Plugs? problematic ?
Old Feb 10, 2018 | 09:06 AM
XRACER63's Avatar
Icon5 NGK Wires and OEM Plugs? problematic ?
I've read post after post regarding errors coming up after replacing their wires and Plugs with NGK. I don't know if their is a problem with this combo , but it seems like it is consistent with misfire and idle. What do you think?
Old Feb 10, 2018 | 11:15 AM
GhostAccord's Avatar
Default Re: NGK Wires and OEM Plugs? problematic ?
I have never had any issues with them. Bosch and other brands on the other hand, a lot of issues.
Strange that you seem to have read post after post regarding errors using this equipment. I'm sure if you Google issues with NGK those are the only threads that will come up. Can you site some examples please? I have been on this forum for 11 years and rarely ever see issues with NGK or Denso parts on Honda's. Other than user error or out of the box part failure, the latter is not very common.
What seems to be your specific issue with these parts?
Old Feb 10, 2018 | 12:12 PM
angrysmileyface's Avatar
I've never had a problem in running ngk plugs or wires. In the last 12 years I've had 3 hondas, (2 5th gen accords, 1 5th gen civic). I've used denso and ngk plugs and if anything simply an improvement over getting the car without them. Also have used ngk wires without any issues plus the blue looks snazzy to boot.
Old Feb 10, 2018 | 12:38 PM
XRACER63's Avatar
I agree the blue does look good I just was reading all the 1399s and including idle issues I could swear quite a few just change tgeir Wires lol. It’s due to that’s the first remedy on the mark.
Old Feb 10, 2018 | 02:41 PM
Sumitomo and NGK plugs would be my No.1 choice.
NGK wires and NGK plugs are my No.2 choice. I have installed them with out issues when Sumitomo wires were not in stock.
Never run into a DTC P1399 with new component NGK installs over the past 27 years. So to answer your question No. there are no common issues with NGK wires or plugs.
Am I to assume that your check engine light has come on and you have pulled a DTC P1399. Is this after a new component install?
Old Feb 10, 2018 | 04:18 PM
holmesnmanny's Avatar
i dont think any person in history has ever had issues with an ngk installed part
Old Feb 10, 2018 | 05:31 PM
OP, have you replaced your smoking catalytic converter yet?
Failed cat code + rough idle/open throttle to maintain idle with little to no exhaust out the tail pipe = clogged cat!
Old Feb 11, 2018 | 03:51 PM
XRACER63's Avatar
Little exhaust or tail but more from under car
digitalvice
17
Mar 25, 2013 03:14 PM
meagainsttheworld
10
Mar 27, 2007 08:37 PM
abnaasefmb
Mar 19, 2006 10:06 PM
knowtomorrow3001
Dec 31, 2003 12:59 PM
N~FaMouSKhMerBoi
11
Jul 7, 2003 12:48 PM
