91 Hatch Rear Brake Swap
Old Feb 5, 2018 | 06:50 AM
b20vtecGSR's Avatar
Default 91 Hatch Rear Brake Swap
I have a 91 hatch and DA rear trailing arms, brake hoses, camber and toe links, prop valve, etc. The only thing missing from my swap now is ebrake cables. When I looked, I saw that the sedan and hatchback have different length cables - about a 2 inch difference, but I had never seen anyone specify which to use.
What cables did you guys use for your swaps?
Old Feb 9, 2018 | 11:10 PM
SKO's Avatar
SKO
Default Re: 91 Hatch Rear Brake Swap
You can use the DA cables.
Old Feb 13, 2018 | 07:32 AM
BETaEF's Avatar
So i found a swap from a 93 Del Sol on the ol' Craigslist. Complete with Ebrake lines and calipers.
I replaced the trailing arm bushings, and the cables worked. I had to modify the long threaded rod, making it longer, but all the ebrake fastners went into same bolt holes.
JaHnAbOi
26
Jun 17, 2005 04:00 PM
pr_tony_montana
Dec 11, 2004 07:14 AM
Sleeper Sii
Sep 15, 2002 03:44 PM
91sifreak
Aug 30, 2001 12:56 PM
