Msd cap
Old Feb 2, 2018 | 08:53 PM
xlusiveracer's Avatar
Default Msd cap
I’m running a msd on my distributor and I’m getting green deposits on my cap.msd doesn’t sell the caps separate only as a whole.is it ok to just use a stock cap and be gone with the msd or do I need to get a whole new distributor?
Old Feb 3, 2018 | 07:39 AM
Default Re: Msd cap
so nobody knows if I can use a stock cap
Old Feb 3, 2018 | 06:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Msd cap
Don't be passive aggressive... it won't help your situation and doesn't endear you to the community. You posted eleven hours ago.
If you get rid of the MSD coil and external coil style cap, you can use a stock cap if you install an OE coil and rewire the distributor for the stock coil. This isn't necessarily going to fix your "green" issue... that is unless your wiring for your external coil is passing through the cap and there is a way for moisture to enter the distributor.
Old Feb 4, 2018 | 09:21 AM
civic402lx's Avatar
Default Re: Msd cap
Why are you running the msd cap in the first place anyhow? Heavily modified? Stock daily?
Old Feb 10, 2018 | 05:44 AM
Default Re: Msd cap
It came on the car.its built high compression 13:1 but it’s tuned for daily.sorry i was looking for a quick reply cause im having trouble getting my car starting.before it would start and a cel would come on when it’s warmed up.when I try to check it all it gives me I straight long blinks.i checked the cap and there was light green deposits
Old Feb 10, 2018 | 05:56 AM
Default Re: Msd cap
Would you say it’s my distributor cap causing the cel?
Old Feb 10, 2018 | 07:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Default Re: Msd cap
One straight long blink is a code 10... which is a bad IAT sensor/circuit. A short single blink would be an O2 sensor problem. Either one... or both can cause driveability issues.
Old Feb 10, 2018 | 07:47 PM
Default Re: Msd cap
ITs not 1 long blink.all it does is just show me constant long blinks
Old Feb 10, 2018 | 07:52 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Default Re: Msd cap
Just order another MSD replacement cap/rotor button system. Tune up parts.
Old Feb 10, 2018 | 07:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Default Re: Msd cap
Do you mean stays on solid ??? No blink, just a solid light as long as you have the service connector jumped ???
Old Feb 10, 2018 | 09:40 PM
Default Re: Msd cap
No it gives me a long blink.and just keeps blinking long blinks
Old Feb 11, 2018 | 02:47 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Msd cap
I would swap back to OEM distributor
aftermarket ignitions plays havoc on honda engines and OEM have been proven reliable.
theres an Accel internal coil #10110 i think which works great with OEM. Use OEM caps as well.
Old Feb 11, 2018 | 06:32 PM
Default Re: Msd cap
Can you swap out the coil without removing the distributor?
Old Feb 15, 2018 | 08:04 PM
Default Re: Msd cap
Got the car started.fixed the code.think part of the problem is my main reply.but lately when I’m driving no matter what gear I’m getting an in and out tick.can hear it mostly 3k rpm and up.tick doesn’t get louder but you can hear it.kinda sounds like something small rolling around in the intake manifold.or a sound like some electrical short.any ideas?
Old Feb 16, 2018 | 05:08 AM
civic402lx's Avatar
Default Re: Msd cap
Valve lash adjustment?
Old Feb 16, 2018 | 06:15 AM
Default Re: Msd cap
I haven’t ran into a car that need valve last adjustment.is that what it could be?any other ways to tell on my own?will it hurt my car if I drive it like that?how much does it usually cost to have adjusted cause I can’t do it myself
Old Feb 16, 2018 | 08:09 AM
civic402lx's Avatar
Default Re: Msd cap
Thats something you need to call your mechanic and ask for price. Everyone charges differently. Where exactly is the noise emitting?
are you mixing up the injectors noise instead? Pin point exactly where it is coming from.
Old Feb 16, 2018 | 10:38 AM
Default Re: Msd cap
To me to sounds like the intake manifold I thought the new iat sensor would fix it but guess not.i can’t hear it at idle but when I above 3k I can hear it and feel it from the throttle cable
Old Feb 16, 2018 | 10:39 AM
Default Re: Msd cap
Could it be injectors?my fuel rail is covered in black deposits if that is the sign of anything
Old Feb 16, 2018 | 12:05 PM
civic402lx's Avatar
Default Re: Msd cap
Take them off and give it a good clean. See if it return. You maybe running rich, extra carbon build up. How old are the injectors?
Old Feb 16, 2018 | 12:36 PM
Freedo_Civegra's Avatar
Default Re: Msd cap
A new dizzy can be had for like $70
Old Feb 16, 2018 | 01:26 PM
Default Re: Msd cap
not sure how okd they are but it is a rebuilt B20vtec had has than 5k with the new set up
Old Feb 16, 2018 | 01:28 PM
Default Re: Msd cap
you think that’s what’s causing the ticking noise.i suppose I should get a new one since I didn’t switch out my old msd cap.but the car is back to not starting again so I think I might just have to switch it to stock this time.whole new stock distributor is 70 you said?
Old Feb 16, 2018 | 05:05 PM
civic402lx's Avatar
Default Re: Msd cap
Uh, most people on here will tell you to stay away from aftermarket distributor. Honda motors doesnt like it too much. Cause too many isssue.
Old Feb 16, 2018 | 05:19 PM
Default Re: Msd cap
Ok well it came with the car so it wasn’t my choice
