D16Z6 swap on 96 ek
Old Jan 31, 2018 | 08:25 PM
Sam19's Avatar
Default D16Z6 swap on 96 ek
I’m trying to figure out all the stuff I need for my swap on my 1996 Honda Civic coupe. I’ve been reading and a lot of people recommend a y8 harness with y8 injectors and a p28 ECU which I already have. I’m just not sure what else I would need other than the harness and injectors. Wouldn’t I need a different alternator bc of the different plugs? I’m in need of some help from anyone and i would really appreciate it lol
Old Feb 2, 2018 | 11:49 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: D16Z6 swap on 96 ek
Why not just get a D16Y8 complete engine/tranny and be done with?
Old Feb 5, 2018 | 05:19 AM
Sam19's Avatar
bc it’s already in the car and they’re the same engine.
Old Feb 5, 2018 | 07:54 AM
NVturbo's Avatar
O.G. triple O.G.
same engine.....NO.
Old Feb 5, 2018 | 09:28 AM
tony_2018's Avatar
Fish Twig
same engine....please describe. I'm so interested in this explanation.
Old Feb 6, 2018 | 02:39 AM
NVturbo's Avatar
O.G. triple O.G.
.....because it says VTECH. lol
Old Feb 6, 2018 | 07:05 AM
tony_2018's Avatar
Fish Twig
I wanna know OP, don't be a ghost now. Get it while your alive.
Old Feb 26, 2018 | 06:03 AM
Sam19's Avatar
**** y’all. I came here to get help on my car, not to deal with stupid **** 🙃
Old Feb 26, 2018 | 11:13 AM
CandyRedRC46's Avatar
lol
Old Feb 26, 2018 | 08:06 PM
countrynoob's Avatar
From: Whats Up MN!! But still the middle of nowhere...
Unless you plan to boost it or something, I don't really see a point in swapping in a D16z6 when you already have a D16y8. They practically have the same output.
Even if you plan to boost it, you will have to open it up unless you are satisfied with sub-par 200 hp and drive pretty mild like me. I hit redline maybe once a month?
If you still plan to do it, you can just get the motor and swap in parts from your Y8 (Distributor and Throttle Body) and keep the same wiring. You will retain OBD2 and the computer probably would not notice anything different.
Now if you plan to go OBD1, you would need a jumper harness, the P28 and the Z6. You can still use your transmission from your Y8. I believe the shift forks in the Y8 are of better material than the Z6. The thread that confirms the transmission will be hard to find. It has been a couple years.
Old Feb 27, 2018 | 05:30 AM
OP already stated D16z6 is in car now and he has a p28....
Old Feb 27, 2018 | 08:41 PM
Well, op is going to have a hard time with that P28 either way.
https://honda-tech.com/forums/honda-...rness-1117688/
Old Feb 28, 2018 | 05:31 AM
Pretty sure OP is already having a hard time lol.
Old Feb 28, 2018 | 11:18 AM
tony_2018's Avatar
Fish Twig
**** OP getting made at me for? I wanna know, I came to learn what makes the z6 the same design as the y8.
Old Feb 28, 2018 | 11:33 AM
DEY BOF SOHC VTEC PAPA
el_gabinaso_eh9
Jul 25, 2015 01:42 PM
biff206
42
Nov 5, 2013 02:54 AM
thechuckster17
Aug 29, 2006 08:57 AM
smxr1
Dec 14, 2001 10:44 AM
