ZC sputtering/surging
Old Nov 12, 2002 | 02:44 AM
90Zcrx's Avatar
Default ZC sputtering/surging
My daily driver 88 civ hb is sputtering and surging at all RPMs. It feels like it's missing on almost a rythm. I've changed out the o2 sensor, coil (put in a blaster 2 and MSD 6a), and igniter. What else could it be? I'm at a total loss and it's getting worse.
Old Nov 12, 2002 | 08:42 AM
wronghand's Avatar
Default Re: ZC sputtering/surging (90Zcrx)
Are you getting a check engine light? If so what is the code?
Old Nov 12, 2002 | 11:36 AM
Superhatch's Avatar
Check the grounds....all of them!!! and then check them again!!!
-Jake
Old Nov 12, 2002 | 11:41 AM
Hondasaurs's Avatar
Default Re: ZC sputtering/surging (SuperHatch)
Check your cap and rotor. If your rotor is loose it will sputter and even stall. If this is ok then you may want to check for a spark on all cylinders
Old Nov 15, 2002 | 08:41 AM
infamousALLMTR's Avatar
Default Re: ZC sputtering/surging (ZC_CRX)
unplug your ecu and let it sit for 30 sec... sometimes works
joesmoe23
Jan 26, 2012 09:33 PM
invision
Oct 7, 2007 07:44 AM
josegaitan
Nov 18, 2004 05:48 AM
CWBETB
May 29, 2003 07:54 PM
kolk1
11
Mar 6, 2003 04:42 PM
