2007 Odyssey testing driver's side power window
I have a 2007 odyssey that the driver's side power window no longer goes up or down. All other windows are fine. I removed the motor/regulator and I would like to test out the motor by running 2 wires from the car battery directly to the motor. There are 6 contact points on the electrical connection of the motor. Can anyone tell me which of those 6 connections I should make contact with to test our the motor? Any help would would be great!
You could have more easily tested the motor without even taking it out by jumping a few wire terminals at the driver's master switch harness connector.
Regardless, since you already removed it: Apply power (+) to terminal no. 1 (Red/Blk wire) and ground (-) to terminal no. 4 (Red/Yel) to raise it. Switching power and ground to those two terminals reverses it.
96civic808
Dec 13, 2015 05:35 PM
all_conference
Dec 1, 2007 05:47 AM
