power window question??
Old Jan 28, 2003 | 10:54 PM
jdm169's Avatar
Default power window question??
okay so i'm installing a universal power window kit by spal and was just wondering... when i just connect the red and black wires from the main motor (power and ground) the motor turns the crank one way( rolls the window up)... now i'm wondering what makes the window roll down, what makes the motor run in reverse. There's no control module i'm thinking it's just how you wire the switches?
Can anyone who has a little knowlege of this help explain this to me and how i would wire it up. thanks
Old Jan 28, 2003 | 11:09 PM
audioroach's Avatar
Default Re: power window question?? (jdm169)
well most motors like that are reverse polarity type...when you reverse the pos and negative wiring the motor works in the opposite direction.
Old Jan 29, 2003 | 08:54 AM
ratherbewalking's Avatar
more info, what kind of car do you have?
Old Jan 29, 2003 | 09:27 AM
Desslok's Avatar
Default Re: power window question?? (audioroach)
Yes. One wire rests at ground and the other wire gets power. The switches are I believe 5 wire?
Old Jan 30, 2003 | 11:40 PM
jdm169's Avatar
Default Re: power window question?? (Unexplained 98 percent)
it's a 91 crx si BTW- if anone else has some info i'd be interesed in learning more thanks for all your help... i was reading another post where the 5 post switch had like post 3 and 5 conected together and 2 and 4 connected or something like that which ties in to the reverse polarity
suradnoh
Feb 5, 2018 05:18 PM
EFin' Kyle
Feb 7, 2012 02:51 PM
civicseth
Dec 14, 2005 10:18 PM
hatched91
Jun 13, 2005 03:43 PM
david90
May 31, 2004 08:01 AM
