2006 honda civic oil leak passanger side
I just changed the cam plug and valve cover gasket on my 2006 honda and oil still leaking. Its not the main seal and it is coming from the top of the engine above the power steering pump. I still cant track it down. Anyone have any suggestions ?
I have the Si K series so not sure if placement is the same. For me, the back side passenger side has the vtec solenoid (gaskets leak there), the oil pressure sending unit which can leak, especially if it gets hit with an oil filter wrench etc. And also on the back in the area is the oil cooler that has an o-ring under it. The oil filter then screws onto it.
If the R18 with it's sohc vtec is anything like the K20, then those items could be in the vicinity and leak.
swertepinoy
Feb 27, 2010 10:55 PM
