(Not important) dj27nitros EJ1 update
How’s it going fam. Just wanted to talk about the things I have done so far and would like to hear what you guys think I should do next .
(Work done )
lets start off with after Christmas , I installed a skunk 2 short throw dual bend shifter . Also received was catback exhaust system . D spec brand . The car shifts so smooth with the new bushings and short throw , also the exhuast is very loud after installed the highflow cat. Like pretty ricer loud .. the exhuast hangs low and scrapes so I still have to raise it up .
(Engine wise)
i have decided to build my D serious engine . I know many of you will tell me it’s not worth it and I’m wasting money .. but here’s my plan
Ycp vitara pistons on skunk 2 (or eagle ) h beam rods
new pistion rings , felpro headgasket , arp headstuds.
(Further engine parts I may or may not install )
might do cams but I don’t think that’s in the budget . Budget - 1,200 (with turbo kit
(turbo kit and misc)
ebay turbo kit ($400-700)
bigger injecters
(maybe) - fuel rail ???
manifold ???
bigger throttle body ??
Pictures of what my car looks like now inserted .
Let me know what you guys think I should or should not do .
Do you already have an ECU and clutch?
And before putting money into things like throttle body, fuel rail, or intake manifolds I'd consider re investing that cash into better name brand turbo components.
OP is this going to be a build thread?
As it stands now it's an appearance and opinion thread. Neither of which should be in this technical section.
End result is either a move to the appearance/picture section or closure.
Please advise.
Please advise.
this is follow up to a build thread . But if this post is in the wrong area , please delete it because I do not know how. Further wise I don’t have any Honda friends so this is why I come here to ask the questions.
Your first post you state you have decided to build your motor/car and show the mods you have already done.
Now you are saying this is after you've got done building the car/motor....
I won't delete the thread. I could move it or close it. However, it sounded like you were going to get into building it. As such, I wanted to know the direction your intentions were with this thread.
Please read the rules sticky at the top of the forum, it will give you the idea behind the build thread. Then you can document your build as well as get feedback to questions etc.
Dude got no idea what is going on. 1200 budget to build a car. Best to spend that 1200 fixing up the horrible paint job and body work. Get rid of the fart can. Clean up the interior. Goodness, some body got creative with the stereo. Cutting the dash to put a double din HU in, just so it hang loose. Im still scratching my head on what is going on here or where it's going. Does the radio fall out if you pop the clutch and take off fast?
Ebay turbo? All i can think off is, *kaboom*. Bye, bye motor..
but, nontheless, good luck with your build.. your car, your money..
i have questions, why? Because curious mind want to know.
*is that a glow in the dark steering wheel?
where in the hell is the steering column cover?
what happen to the climate control? I'm guessing you dont need heat or a/c?
what is going on with the back wheel? why does it look like it is broken? That is def not normal.
shift ****, uh...uh.. i dont know what to ask here.
is that a rear windshield visor?
danseng28
Aug 15, 2008 01:46 PM
PiXeL
17
Jan 11, 2006 04:37 AM
phu chai khao
Apr 16, 2005 02:58 PM
gobblebox59
Jun 7, 2004 06:17 AM
SPORT INJECTION
May 12, 2003 07:02 AM
