B20b (CRV) into 2000 Civic EX help!
Hey so I have a D15b as of right now in my 2000 Civic coupe EX, I plan on dropping a b20b from a CRV into my car however I’m confused what ECU or Wiring Harness I will need. My plans are to have a B20b low comp block, b16a2 high comp cylinder head, and an LS Transmission. But can someone please help me out by telling me if I’m able to use the same ECU and get a b20b wiring harness or what? Thanks!
- The wiring harness you currently have will be fine.
- NO the ecu you currently have should not be used for the B20 Vtec setup.
- I suggest a chipped OBD1 ecu and OBD2b to OBD1 ECU conversion harness
- Make sure the chip provider installs a tune on the chip that matches your setup (you will eventually want an actual tune though.)
- Enjoy and have fun.
The wiring harness you currently have will be fine, just that some plugs will go unused like the vtec harness etc.NO the ecu you currently have should not be used for the B20B.I suggest a P75 OBD2B ECU from 99-00 Integra, no conversion harness needed it will be plug-and-playEnjoy and have fun.
The JDM B20B engine I believe is missing the crank position sensor, and maybe some others too that a USDM OBD2 ecu like the P75 would look for.
That being the case, you can probably run an OBD1 94-95 Integra ECU and an OBD2B to OBD1 conversion harness and be fine.
irideslammed5021
May 14, 2007 11:00 AM
