98 Honda Civic temperature problems
Hey, the temperature in my 98 Honda Civic was going up and down so I replaced the thermostat and changed the coolant. It worked fine for about a week; it would stay at one temperature and the heat was good. Now it is going up and down again. The resovar was above the max fill line when I got home but I wasn’t able to check the radiator, to hot. Any ideas? Thanks.
You have to check in the radiator, when cold. The radiator should stay full to the top. Park the car on level ground or facing uphill then wait until it is completely cold before opening the radiator.
One common reason for coolant leaving the radiator and overflowing the reservoir tank is a slow leak in the head gasket.
Unplug the radiator fan connector at the thermostat housing. Using a paperclip jump the 2 terminals together. Let us know if the fan comes on.
and did you ENSURE that you have bled the cooling system of air?
The tool in this video can be rented from most auto parts stores for a small fee:
milkwasabadidea
Jan 8, 2011 10:22 AM
TailZ
Honda Civic (2001 - 2005)
Jun 14, 2010 10:52 AM
Al-sonic
Jan 12, 2007 10:38 AM
