Premature Wheel Bearing Failure
Old Jan 14, 2018 | 01:52 PM
MotorMouth93's Avatar
10 Year Member
Default Premature Wheel Bearing Failure
I replaced both front wheel bearings on my Integra a few weeks ago and now the front driver side wheel is loose again. I used Timken bearings which are stamped Koyo made in Japan. Is there any suspension or brake problem that could cause this? Unevenly worn brake rotors? Possibly counterfeit bearings? My suspension is all tight as far as I can tell and the steering rack feels like it might have a bit of play (the rack/pinion itself, tie rod ball joints are nice and stiff) but I don't feel any vibration or anything that you'd expect if it was rattling itself apart. I had a friend of a friend install them for me so maybe that was done incorrectly somehow? Even still, I'd expect more than 2 weeks of life out of the bearing even if it was installed with a ******* hammer.
Old Jan 14, 2018 | 05:29 PM
tamboo's Avatar
10 Year Member
Default Re: Premature Wheel Bearing Failure
possibly too much pressure was applied to the inner race, that will **** it.
https://honda-tech.com/forums/honda-...ement-2685054/
Old Jan 15, 2018 | 11:41 AM
tony_2018's Avatar
Fish Twig
It also depends on how you pressed in the bearing and the hub. If you didn't support the bearing properly when pressing in the hub you probably did fucked it and fucked it good you did.
Old Jan 15, 2018 | 01:38 PM
10 Year Member
When I replaced the bearings about a year ago I used the method outlined in the post linked by tamboo, I figured that was what caused the failure so I took them to a shop to have them done with a proper press. It was a cash under the table deal with a friend of a friend and I didn't see how he did it so that could be the cause I suppose. I guess I'll just do it again with bearings bought straight from Honda to make sure they aren't counterfeit and pay a machine shop to do it properly.
Old Jan 16, 2018 | 08:59 AM
tony_2018's Avatar
Fish Twig
PM me when you're ready. I'll give you a hand with it. Just make sure the spindles are off the car.
Old Jan 19, 2018 | 01:21 PM
10 Year Member
Thanks I appreciate it! I somehow never realized you were in Austin too lol. I'm aiming to get it taken care of next weekend.
Old Jan 22, 2018 | 03:54 AM
tony_2018's Avatar
Fish Twig
This weekend I'm occupied, dog sitting and working.
spyderazn
Mar 9, 2008 05:28 PM
James
Sep 1, 2004 04:47 PM
justinau
Dec 11, 2003 07:35 PM
Takeoff
Feb 23, 2003 09:22 AM
akpsi
Oct 2, 2001 08:20 PM
