P1456 Name of canister in pic, replaceable as I am smelling fuel?
Old Jan 12, 2018 | 02:47 PM
arielb1's Avatar
Default P1456 Name of canister in pic, replaceable as I am smelling fuel?
Hello,
I have Accord 1998 EX 2.4 and been getting P1456 DTC. I can smell gas coming out of this canister. The hose marked "A" was lose so I zipped tied it, but the code came back. Is this canister a replaceable part?
The evap canister and vent valve solenoid that sits ontop of the canister are in good shape as I can see. As of now, my focus is the smell coming out of the canister in the picture. What is this part called? Thinking it might need to be replaced.
My next step is to get a smoke detector,but Im thinking the canister in the picture is the problem. I shouldn't be smelling fuel coming out of it
Thank you in advanced
Old Jan 12, 2018 | 03:37 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: P1456 Name of canister in pic, replaceable as I am smelling fuel?
EVAP 2 way valve.
PerformanceFirst's Avatar
Maybe 27 in this picture?
https://www.hondapartsunlimited.com/...el-pipe-1-scat
Does it open up?
Old Jan 12, 2018 | 06:24 PM
arielb1's Avatar
Does it open up?
I opened it and was inside. Note the two hoses on the right. I zipped tied the bottom hose as it was lose. Top hose was very tight. I think this unit maybe cracked..thanks in advanced
Old Jan 12, 2018 | 06:32 PM
arielb1's Avatar
Originally Posted by tech8
EVAP 2 way valve.
Thank you.. I see a pic on ebay. It looks just like mine. Is this a well know wearable/replaceable part? thank you again... I appreciate you.
Old Jan 13, 2018 | 12:32 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
It may or may not be due to the 2 way valve. Since you are smelling fuel, pull both hoses off the 2 way valve.
If fuel runs out of either hose, the FTVR (fuel tank vapor control) valve is malfunctioning or the fuel tank is being overfilled. A few drops of fuel is normal.
hecubus
Feb 21, 2014 04:47 PM
B_Swapped93
May 18, 2013 06:52 AM
TylerC161
Jan 9, 2007 09:19 AM
Confucius37
Feb 11, 2005 08:48 AM
douglas_be
Mar 11, 2004 07:14 AM
