Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Misfire!
Old Jan 2, 2018 | 09:54 AM
famo-outdoors's Avatar
Default Misfire! Please help
Hello all, first time poster here. Just picked up a 2001 civic lx 5 speed for dirt cheap. Problem was it was idling very rough but would clear up when driving. When I took it home I pulled the codes in it it and showed it had a misfire on cylinders 3&4 and it had a code related to the iac valve. Upon inspection the idle air control valve looks brand new and was unplugged. Plugged it back in and ran a little better but still had a misfire on the cylinders 3&4. I pulled the plugs and they are brand new as well, but cylinder 4 plug had an oversized spark plug in it. So I swapped coils 3&4 with coils from 1&2. And the misfire stayed on 3&4. I couldn’t run a compression check on #4 because of the hole was too big but cylinder 3 had 135 pounds of compression. However when I checked cylinder 2 it came up with only 35 pounds of compression and when I checked cylinder 1 it had absolutely 0 pounds of compression. I added oil to cyl 1&2 and the compression didn’t rise at all. Now, the car doesn’t appear to leak antifreeze but it is losing it and there appears to be oil in the radiator. It does not blow white smoke from the exhaust and there in no coolant in the oil when I checked the dipstick. So any ideas what it could be? It almost seems like a bad head gasket but the fact that cylinders 1&2 are almost completely dead and cylinder 3 has decent compression but still has a misfire has me a little stumped. I’m still not sure how the front 2 cylinders are almost completely washed out but do not misfire but the back 2 do misfire. He car has 281k miles but is in awesome shape otherwise so I would not be opposed to putting a used engine in but if I could salvage the current one and save a little money, I would much rather go that route. So any ideas? Look forward to hearing from everyone.
Old Jan 3, 2018 | 01:42 PM
holmesnmanny's Avatar
Default Re: Misfire!
what does mechanical timing look like ?
Old Jan 3, 2018 | 02:55 PM
Figured it out. Was looking at the harmonic balancer and noticed a wobble, went to remove harmonic balancer and the bolt head broke off in the crank shaft! Was able to weld a nut to what was left to the bolt and remove it. Upon further inspection the crankshaft was actually bent and caused the timing belt to jump some teeth. Is this a common problem with these engines? In all my years of automotive experience I’ve only ever seen this once and it was on a Kia sorrento. I’m not even going to attempt to save this thing, time to swap in a long block swap.
Old Jan 3, 2018 | 04:19 PM
never heard of a honda crank warping
how did you confirm ?
Old Jan 3, 2018 | 05:54 PM
Looking into the crank where the bolt goes you can see it is slightly bent, bolt will not go all the way in either. Goes in about half way and then stops, turning the engine by hand with the plugs out you can see the snout is bent
Old Jan 4, 2018 | 08:27 AM
the only way i can see that happening is if someone hit the crank bolt with a propane torch to try to get it off
WestyNaut92
May 21, 2018 05:20 PM
stwokay
Aug 26, 2014 08:56 PM
AnthraxVX
Sep 30, 2006 07:09 AM
cxVtecC1
Feb 18, 2005 06:54 AM
imgonnalie2u
Jan 11, 2005 08:05 AM
