1989 Civic LX
Old Jan 1, 2018 | 03:33 PM
Azion26's Avatar
Icon5 1989 Civic LX
My heater fuse keeps blowing. It blew the other day and some bluish smoke came from near the glove box. I pulled the fuse, it wasn't blown. Decided not to put it back in until a couple days later, it's still blowing hot, but I'm afraid to use the heater. Any suggestions why the fuse keeps blowing and what i should do?
Old Jan 1, 2018 | 07:04 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: 1989 Civic LX
Which fuse number is blowing, and what size fuse are you putting in there?
Does your heater blower work on all 4 speeds, and are all 4 speeds different? If not, check your heater blower resistor.
Old Jan 2, 2018 | 01:39 PM
~sp33~'s Avatar
EFB055
The resistor is behind the glovebox, check that.
Check any aftermarket wiring usually wiring problems stem from a bad head unit install or aftermarket alarm.
Old Jan 3, 2018 | 01:58 PM
Azion26's Avatar
So I checked, the heater motor is the fuse that keeps blowing, no fuse number. I am putting a 30 fuse in there when it blows. I think the blower only worked on the 3 and 4 speed. Where is the resistor and what am I looking for?
Old Jan 3, 2018 | 10:28 PM
~sp33~'s Avatar
EFB055
A blown resistor shouldn't trip a fuse, but its common for your lower fan speed circuits on the resistor to blow first. It's behind the glovebox, remove your glovebox and you cant miss it.
Looks like this:
LUDE21
May 31, 2007 01:52 PM
mommyslittlegreaser
Nov 7, 2004 12:21 PM
playerzz
Nov 11, 2003 12:22 AM
NiCkArInO
May 11, 2003 09:13 AM
