F22b2 crank H22a1 block
Hi everyone, I just recently picked up a block (H22a1). But it did not come with a crankshaft. I have a crank from a f22b2 that I want to use so I don't have to buy one. But idk if it fits or will it work after it fits. Can I get some info/help...
The stroke of the F series crank is 95mm whereas the H22 crank is only 90.7mm, so to use the F series crank in the H22 block would require using the F series rods as well... and then I am not sure about the pistons. I don't think H22 pistons fit on F22 rods.
projectef
Aug 22, 2007 03:48 PM
