Why does my engine go up n down rpm’s when I give it gas? D16z6
Old Dec 26, 2017 | 09:36 PM
Sam19's Avatar
Default Why does my engine go up n down rpm’s when I give it gas? D16z6
hey guys, I’m trying to find out why my car idles up and down when I give it gas. I’m really confused, I checked my iacv and it looked fine and I tightened the fitv and the fixed my idling issue but now it starts a little rough and My rpm’s still go up when I give it a little gas. If I bring the rpms up it goes away but when I get to the certain area it does it still.. I’m really confused on what could be causing this.. it’s a d16z6 in a 96 civic frame. Any help please?
Old Dec 27, 2017 | 05:37 AM
mk378's Avatar
Default Re: Why does my engine go up n down rpm’s when I give it gas? D16z6
Make sure the throttle cable is not sticking or adjusted too tight. Check your TPS with a voltmeter.
Old Dec 27, 2017 | 02:05 PM
Sam19's Avatar
another issue I have is my RPMs don’t show on the gadge and my speedometer does work either. My gas n temp shows fine tho. I bought a new cluster but it was for an auto and it did the same thing...
Old Dec 27, 2017 | 04:30 PM
mk378's Avatar
Checked fuse 15? Checked for ECU codes?
Old Dec 28, 2017 | 09:25 PM
Sam19's Avatar
I haven’t checked fuse 15, and What do you mean by ecu codes? Are you meaning check the error codes?
Sam19
Dec 24, 2017 11:21 PM
kotton909
12
Mar 30, 2009 09:22 PM
bdubnyc
May 23, 2008 01:13 PM
DjFreeze
May 22, 2005 10:06 AM
