2000 Civic shuts off in the cold
Old Dec 26, 2017 | 10:49 AM
bksk98's Avatar
Default 2000 Civic shuts off in the cold
First off let me say I am new to Hondas, but not cars. I bought a well used Civic from a co-worker and put a timing belt water pump, plugs, wires, cap and rotor along with all new brakes. I have driven the car about 3000 miles and it runs great. This is where it gets odd. Now that the weather is getting cold when I start it up in the morning it runs fine then shuts off after about 5 minutes, I let it sit for a few minutes it fires right back up and no problems the rest of the day. If I come home late for work around 10pm the next day when I leave in the morning it has no issues. Only when it sits for several hours. It is like when it is transitioning from open to closed loop. Has to be a sensor in my mind. Does not spitter just shuts off. I asked the guy I bought it from and he said "oh yeah it's done that for a while only when it gets cold though, just let it sit for a few minutes and it's fine". Any ideas?
K
Old Dec 26, 2017 | 04:45 PM
civic402lx's Avatar
Default Re: 2000 Civic shuts off in the cold
Check main relay
check ignition switch
Old Dec 26, 2017 | 04:47 PM
mk378's Avatar
When it won't start, click the key to on but don't crank, watch for the CEL to cycle on for 2 seconds then go out, and listen for the fuel pump to prime. Also conduct a spark test. You have to do this during the time when it won't start.
Old Dec 26, 2017 | 06:57 PM
bksk98's Avatar
I can definitely here the fuel pump I will do a spark test tomorrow
Chrisongo
Honda Civic (2006 - 2015)
Apr 4, 2016 08:24 PM
piepans
Dec 31, 2013 05:02 AM
BOMBCRU
12
Dec 4, 2009 06:54 PM
M2B4
Mar 1, 2008 08:42 PM
