Idle problem after OBD2 to OBD1 Ecu swap.
Hi all, I swapped in a chipped P28 ecu with a basemap for my engine to my JDM 97 hatch with a D15B. I did the swap with a OBD2 to OBD1 conversion harness. The car runs great with the stock ecu, but as soon as I plug in the P28 ecu, the idle is really high (2000rpm). At first I thought it was a vacuum leak, but ruled it out.
Is there anything I'm missing from the swap that may have caused the high idle?
So apparently this was my problem, I have the conversion to do....I have the auto manifold with the holes blocked off, so Im going to have to drill the holes for the new IACV
jdm_vtec
May 24, 2007 01:19 PM
SPiFF
11
Sep 2, 2005 05:32 PM
