SRI Intake tube fabrication design ideas
Old Dec 21, 2017 | 10:14 PM
fuzzysig's Avatar
Default SRI Intake tube fabrication design ideas
im assuming a straight arrow intake tube would have the most unrestricted and lowest turbulence flow to throttle body
but obviously not happening in most engine bays.
which would be better?
a sharper bend at the throttle body and straight pipe all the way to filter
a straight pipe from throttle body and sharper bend before the filter
or an even curve from TB to filter?
Old Dec 23, 2017 | 06:27 PM
DumpdEJ6's Avatar
I like the tuna here
Default Re: SRI Intake tube fabrication design ideas
I'm by no means a math wiz, but from what I've gathered regarding my research into airflow, you want the largest radius bends possible, period. There are a lot of tricks as far as varying pipe diameter before, during, and after a bend that I don't really know enough of off the top of my head to reiterate now, but largest radius bends = better. So basically split the difference at the throttle body and the filter.
Old Dec 23, 2017 | 11:01 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
A single curve from the throttle body to the filter would be the smoothest flow.
How to determine the length of the pipe, the radius of the curve etc would take Dyno tuning to see what works best.
Old Dec 24, 2017 | 03:59 PM
fuzzysig's Avatar
Old Dec 25, 2017 | 06:07 PM
DumpdEJ6's Avatar
#2 would be best in those pictures, all else being the same.
Old Dec 25, 2017 | 11:28 PM
fuzzysig's Avatar
thats what i was thinking
what about the design in #3
having an extension to a short ram
or even having some kind of bypass valve right at the throttle body to give you that bump right after throttle tip in that you usually see when mounting a filter straight on the throttle body?
i was thinking of using that aem bypass filter on the throttle body with a custom length tuned short ram and the extension similar to #3
wonder if anyone has done anything like that and tested on a dyno.
i might just do it if nobody else tried it
Old Dec 27, 2017 | 06:37 AM
DumpdEJ6's Avatar
Pretty much the best thing you can do for peak power, (that has been dyno proven) is a 3'-4' long tube the same diameter as your throttle body, with as few bends as possible, with bends the largest radius possible, connected to a velocity stack located outside the engine bay on the front of the car.
Old Dec 27, 2017 | 06:44 AM
DumpdEJ6's Avatar
This is my car in street mode, short ram with velocity stack and a filter:
This is track mode. An extra 2ft-ish long 45 degree bend pipe that goes through an old shitty headlight I cut out and painted, with velocity stack and no filter. It only takes maybe 10 minutes to switch out at the track.
Track mode with hood closed:
Civic Racer X 7
11
Jun 24, 2015 10:17 PM
hillbillycivic
Nov 6, 2012 03:59 PM
eg4sheezy
May 5, 2004 09:03 PM
Starrman85
Aug 7, 2003 12:27 PM
Rising sun #1
Jun 20, 2003 07:56 PM
