JDM DC2 steering rack
Old Dec 20, 2017 | 11:30 AM
DB8_TYPER's Avatar
Default JDM DC2 steering rack
Hi guys will JDM 98 / 99spec DC2 steering rack bolt straight on to JDM 96spec DC2 do I also need to change power steering pump and lines from JDM 98 / 99spec or I can still use 96spec lines and pump.
Old Dec 20, 2017 | 09:36 PM
JDM_JNKY's Avatar
Default Re: JDM DC2 steering rack
It should. RHD to RHD yes, RHD to LHD no.
Old Dec 21, 2017 | 01:05 AM
DB8_TYPER's Avatar
Thanks for your reply, do you know if power steering lines from pump to rack are the same and pump as well or would this need to be changed too from JDM 96 to JDM 98spec
Old Dec 21, 2017 | 02:01 AM
feck's Avatar
Loved
Community Favorite
If I recall correctly the rack and power steering assembly didn't change across the DC2's from 96-2000(from 1.6 base models to the R). I have heard rumours of a slight gearing change in 1999, but last time I looked I couldn't find anything definitive about that. I personally know a chap whose rack wore out on his R(the seals went and grease dried up) and he got a replacement one from a scrapped 1.6. Went in no problem. So long as it's RHD to RHD can't see any issue.
Old Dec 23, 2017 | 12:46 PM
DB8_TYPER's Avatar
Thanks mate, just wanted to make sure before I start taking it apart
91efb16a
Jan 13, 2008 08:18 AM
powersteer
Mar 28, 2006 01:57 PM
ibme_uk
Jan 6, 2005 08:23 AM
