93 accord EX has fuel, no spark HELP!
Old Dec 15, 2017 | 04:12 PM
tinavagurly's Avatar
Default 93 accord EX has fuel, no spark HELP!
car died while driving it. now it will not start. checked to make sure fuel pressure is good. I have replaced:
spark plugs
spark plug wires
distributor
distributor cap
distributor rotor
igniter
ignition coil
checked timing belt was good.
cleaned and re-hooked up ground at thermostat housing.
new battery and battery cables.
still no change!!!
i am getting frustrated and running out of patience and money lol. Can someone please help me?!?!?! i dont know where to go from here!!!!!!!
Old Dec 15, 2017 | 05:07 PM
Big D''s Avatar
Default Re: 93 accord EX has fuel, no spark HELP!
Have you checked to see if all 4 cylinders have spark?
did you check the coil for spark
Old Dec 15, 2017 | 05:08 PM
Yes. we checked all four spark plugs to make sure that all four were not getting any spark.
Just replaced the coil with a brand new one.
Old Dec 15, 2017 | 05:15 PM
Big D''s Avatar
did you test the coil? and Igniter again?
I just went through this on my truck, brand new out of the box Coil and a Distributor. defective.
I also bought a defective, out of the box distributor, 4 months ago for a 94 accord.
Old Dec 15, 2017 | 05:20 PM
Really? Damn that’s awful!!! I will be sure to check the coil and igniter tomorrow morning. I was told at this point, the only things left that it could be would be the main relay switch, ignition switch, or low fuel pressure.
QUOTE=Big D';51511558]did you test the coil? and Igniter again?
I also bought a defective, out of the box distributor, 4 months ago for a 94 accord.[/QUOTE]
Big D''s Avatar
this link may help with your Ignition system tests
Part 1 -How to Test the Igniter, Ignition Coil Accord, Prelude (1992-2001)
I Currently have a 94 honda that doesn't wanna start, so I feel your pain. got new parts coming in on the 20th
Old Dec 15, 2017 | 09:38 PM
holmesnmanny's Avatar
check mechanical timing, check injector pulse
Sami1
Jun 6, 2019 04:51 PM
killa_kraze420
Apr 6, 2014 03:52 PM
exxon
Dec 7, 2011 04:14 PM
nonvtec92
Aug 26, 2010 01:46 PM
CptCorN
Jan 17, 2005 06:33 AM
