94 Del Sol, Replaced ECM, still cutting off while driving
Old Dec 14, 2017 | 12:26 PM
rockcat94's Avatar
Default 94 Del Sol, Replaced ECM, still cutting off while driving
Hi All,
My 94 Del Sol, like many I've seen posted here, is cutting out while driving. Sometimes it starts right back up, sometimes you have to wait. Replaced the distributor cap, fuel filter, and ECM (PN 37820-P06-A52, which I bought with a 60-day guarantee on eBay). Still cutting out. Before I replace the ignition module/coil, does anyone know if the ECM requires some reset procedure/sequence to synch in some way? Any other suggestions are appreciated! So frustrating!
Old Dec 14, 2017 | 12:27 PM
rockcat94's Avatar
Default Re: 94 Del Sol, Replaced ECM, still cutting off while driving
Sorry, forgot to mention that the fuel pump is operating.
Old Dec 14, 2017 | 07:09 PM
eghatch9295's Avatar
Stancetard Hate Monger
test ignition switch
Old Dec 15, 2017 | 09:46 AM
Clean2000Ex's Avatar
I've never had this issue with a Honda, but had an issue with my 2005 Pathfinder cutting off while driving. The issue happened once in a blue moon, then started once a week, then finally multiple times a day to where it was scary to drive it anymore. After replacing my ECU, and cam sensors it was finally fixed by replacing the crank sensor.
Old Dec 15, 2017 | 04:54 PM
tamboo's Avatar
10 Year Member
DIY Ignition switch cleaning - Team Integra Forums - Team Integra
phrewil
Nov 3, 2014 05:16 AM
l337jdmride
Dec 24, 2009 06:51 PM
