I was having problems with it absolutely refusing to go into gear. So I was told probably the master slave, so I replaced it. It was worse, refused to go into any gear unless car isn't running. Start car with it in gear it lunges forward like I didn't have the clutch pushed in. And noises coming from clutch area. So I pulled the motor and this is what I see. But I can't figure out what caused it. I see shavings but no broken parts. Can anyone please help before I replace a clutch that doesn't need replacing???
You can see where something grinded against the metal in a circular motion. All springs are intact but the center wiggles and is very loose
