K series trans makes small continuous grind when in gear? What am I looking at?
Car recently started locking me out of gears and now I can’t rev match without a lock out or grind. Trans has small continuous grind when in gear at dead stop. What could be the problem?
Fluid contamination leading to bearing failure. Maybe you're lucky and it's just the throw out bearing. If you keep driving it you'll cause more damage.
bnmm
Transmission & Drivetrain
Apr 28, 2012 12:28 AM
