Mystery Connector! What Is It For?
Old Dec 10, 2017 | 11:17 AM
Jochem17's Avatar
Default Mystery Connector! What Is It For?
Hey all!
First off, I'm new here. I used to be a part of another Honda forum, but find it to be much more informative and all around better here. Anyways, I am currently in the process of converting my manual doors to powered ones; powered windows, mirrors, locks to be exact. I am following the thread of twistedimage for this job and I must say it is very easy and straight forward; it just makes the most sense. Thanks for that!
However, as I am now working on my driver's side I have come across some sort of mystery plug. I have no idea where this connector would originally go and it seems to be connected to the green fuse connector, mirror switch, ground, and continues to the other side of the dashboard harness to five other connectors which I believe is the clock, hazard, defroster, fog, etc. Could anybody confirm this for me? I am guessing it is alright to disconnect it from my makeshift driver side sub harness but I just want to make sure what this plug actually is for? Just in case.
Thanks a bunch!
This is the strange brown connector in question, the wiring leads to other switches which I do need for the swap.
The wire that connects to the brown mystery one is the black and yellow on the left.
The same black/yellow wire then meets upstream the power mirror switch and is soldered here with the same colored wire.
One of the other wires from the mystery brown connector also goes to the ground which is nearest the driver's door (close to fuse box).
The ground wire and two other wires from the mystery brown connector then go to this bundle which I've wrapped up. There are five other connectors here, two small gray ones, a small and thin green one, another bigger gray connector, and a blue one as well. I suspect these are the fog, defrost, clock, hazard, etc. lights. Anybody could help me out?
Old Dec 10, 2017 | 01:47 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Mystery Connector! What Is It For?
What year make and model cars are the harnesses from?
Old Dec 11, 2017 | 02:56 AM
NVturbo's Avatar
O.G. triple O.G.
black/yellow = ACC +12vDC
Old Dec 11, 2017 | 06:11 AM
Jochem17's Avatar
It's an EG hatch, not too sure about the year though, I'll ask the seller from whom I got her from about the year.
Old Dec 11, 2017 | 06:12 AM
Jochem17's Avatar
'ACC' stands for what exactly? Would I be able to just de-pin these since I don't need it for the conversion?
Old Dec 11, 2017 | 06:40 AM
mk378's Avatar
Find out what year you have then get the service manual with schematic for the car.
The model year of any USDM car is coded into one of the digits of the VIN, don't remember exactly how but that is easy to find out online.
Also it would help if you untangle the wires and lay them out on a plain background and take pictures with better light.
Old Dec 11, 2017 | 08:20 AM
NVturbo's Avatar
O.G. triple O.G.
Are you being serious?
Old Dec 11, 2017 | 09:27 AM
Jochem17's Avatar
I'll have a look at the year and schematics then; will also get this untangled and take a more detailed picture once I'm home in a few days and if I haven't yet figured it out. Thanks!
Old Dec 11, 2017 | 09:30 AM
Jochem17's Avatar
Yes. I'm sure you're an expert in this but like me, and I think I speak for many others here, the forums are created as a means to learn and help one another. I'm new to electrics and would like to learn from you and many others here so kindly show a little respect.
Old Dec 11, 2017 | 11:50 AM
NVturbo's Avatar
O.G. triple O.G.
ACC = switch ignition. Meaning it will provide voltage only when the key is in that position "ACC" via relay/switch. It's not constant battery power.
happy now??
4evalearning
Honda Fit
Aug 20, 2015 03:32 AM
Fliptard
Apr 3, 2014 12:15 PM
articsilber323
May 25, 2011 09:29 PM
CeoStatus0
Oct 24, 2007 09:44 PM
BillyBalls
Jul 18, 2007 06:30 PM
