Yonaka H swap mounts
hey all, i bought a set of Yonaka H swap mounts for an EG a while back. At the time, i was building a second car identical to my first. The first car had ENJO mounts though. Anyways when i got the Yonaka mounts i could instantly tell the rear mount that bolts to the subframe was way off. It placed the bushing too far to the passenger side as well as placing it too low. On top of that the bottom side where the bolts go through should be close to level. This mount the rear sits about 1/2” higher which will not work. When i got them, all i got was “well we’ve never had anyone say our mounts wouldn’t fit.” That was all i got. I guess what I’m trying to ask is did i get sent the wrong one, or do the mounts not work at all? Thanks for any input.
You might have better response in the hybrid section. That section is dedicated to non stock motors going into the chassis i.e. H series into a D series chassis.
I can move your thread there if you like.
That would be great if you don’t mind. I apologize, im pretty new to this page.
siregcivic
May 20, 2008 08:24 PM
ForceFed Coupe
Dec 13, 2003 04:19 PM
