EF hatch gas smell whether car is just idleing
Old Dec 9, 2017 | 12:05 AM
Siabraham1990's Avatar
Default EF hatch gas smell whether car is just idleing
might be a noob question, but when I turn on my car to go to school in, I turn it on inside the garage to warm it up a bit since its cold outside but in just that little bit of time the whole garage is filled with the smell of gas. If anyone can fill me in on how to fix it or if that's just normal for it. Its DX and with dpfi
Old Dec 9, 2017 | 07:38 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: EF hatch gas smell whether car is just idleing
Could be injector seals. The problem with DPFI injectors is that when the seals go bad, they can let un-metered gas enter the engine. I literally just took apart my DPFI throttle body and put it back together to investigate the same thing. You can see how clean the inside of my DPFI manifold is, and there is a puddle of gas in there...I'm guessing with the gas leaking past the seals, it is somehow keeping the inside of the manifold clean? Strange thing is, I'm still getting over 30 MPG...
Old Dec 9, 2017 | 11:45 AM
acmoc's Avatar
Well, if it's cold and its in your garage, it's going to smell
Cars run rich on cold start for fast warm up.
The question is if it smells like gas once warmed up. Then it can be any number of things
Old Dec 9, 2017 | 03:54 PM
2x0's Avatar
2x0
10 Year Member
Uhm. You aren’t supposed to warm a car up in a closed garage. Gotta open the door, or better yet pull the car outside to warm up.
The gas smell is normal.
Old Dec 10, 2017 | 02:28 AM
well yeah I opened my garage but to not let all the cold air in I only opened it up a bit. My problems is that even when the car is warm it still throws a strong gas smell but coming from the exhaust.
yeah man still smells even after its warned up
ill take a look at this to see if everything looks good on it.
Old Dec 10, 2017 | 12:14 PM
acmoc's Avatar
Okay, is it warmed up, but in your garage still?
If not, it can be running too rich, or have a bad ignition that's not burning the fuel. Maybe an exhaust leak, gas leak, or bad catalytic converter.
Possibly just a bad gas cap
Old Dec 10, 2017 | 12:17 PM
turns out it was just bad spark plugs. I can still smell gas but at this point I'm assuming that's just normally now for an old car.
Old Dec 10, 2017 | 07:32 PM
acmoc's Avatar
disconnect the battery and let the ecu reset. It probably calibrated itself to compensate for the bad plugs.
It should not smell like gas, mine doesn't at least.
jDm bEeZy
Dec 12, 2005 05:16 PM
Power Rev Racing
47
Aug 19, 2005 03:23 AM
Ha7chB4cK
Jul 26, 2004 01:36 PM
SpoonPL
Jul 11, 2002 06:52 PM
fatoldman7
Aug 16, 2001 01:47 PM
