93 ACCORD EX DIED WHILE DRIVING, NO SPARK
i have a 1993 honda accord ex.
was driving the other day, making a turn. went to switch to second gear, stepped on gas, car shut down. Coasted down the street to pull over to the side to restart; hasnt restarted since.
Replaced, spark plugs, spark plug wires, igniter, distributor cap, rotor in cap, valve cover seals, and coil.
still no go.
not getting any spark, not sure what to try. Any ideas, please and thank you!
still no go.
it doesn't need to start to check for voltage at the coil or the black/yellow wire going to the distributor connector with the ignition set to on
it could be the ignitor that's bad
tinavagurly
Dec 15, 2017 09:38 PM
