D Series into Integra
Old Dec 6, 2017 | 05:02 AM
Dilbones's Avatar
Default D Series into Integra
Hello all,
I'm in the process of building a race car. I bought an Integra shell for my B18B1 swap and since I’ll have a perfectly good integra shell sitting around and a Civic motor, I decided to put the D15B7 from the Civic into the Integra. I have two friends who have done similar swaps (OBD1 D series into Integras) and their cars are running fine. Mine, however, is not.
The problem I'm having now is:
1.) When I turn the key to accessory, the fuel pump does not prime, and
2.) When I turn the key to start the car, I can hear the relay click, but the starter does not crank-- instead, the radiator fan starts.
The car did this once before, but I tried starting it over the course of a couple of days and eventually it cranked over VERY slowly out of the blue.
It ran for a while, perfectly fine—mind you, and then started behaving as mentioned above.
Here are some details around the swap:
  • Car is a '97 OBD2A Integra with manual transmission
  • Engine is out of a 93 Civic DX with manual transmission
  • I am using the OBD 1 ECU from the Civic with a jumper harness
  • I am using the OBD 2 engine harness and I have modified it
    • Soldered OBD1 injector clips onto it
    • Soldered OBD1 alternator clip onto it
      • https://www.hamotorsports.com/obd2-alternator-obd1-harness.html
    • Lengthened IAT sensor to fit onto Civic engine
    • OBD 1 distributor with conversion harness
Any and all help is appreciated. Thanks.
Old Dec 6, 2017 | 08:02 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: D Series into Integra
Why don't you just get another B series motor instead of using the D15? Integras are slow as **** even with a B18B1 and you're running a SOHC non-VTEC???
Old Dec 6, 2017 | 08:42 AM
Dilbones's Avatar
Why don't u kindly eat a dick?
Old Dec 6, 2017 | 02:26 PM
Dilbones's Avatar
This is the swap inside of the car for those of you interested:
Got the car cuz it ran well and had a clean shell. I really want this thing running so I can get started on caging my Civic for next year...
Old Dec 7, 2017 | 02:55 AM
NVturbo's Avatar
O.G. triple O.G.
It's still slow as ****, DICKWAD. If you don't like people's comments, don't make a lame *** thread about stupid **** no one bothers to do.
Old Dec 7, 2017 | 04:06 AM
prakhash's Avatar
^This is the reason the Honda community is going to ****.
I wish I could pitch in and help, but I'm not quite sure about the solution to your problem. Hopefully someone in here will be able to though. I just came in here to say that a car's driving characteristics go far beyond just what motor is in it. I'm sure it will be fun to throw around a track even with a SOHC in it, depending on what kind of other components you're running on your car. Good luck!
Old Dec 7, 2017 | 04:38 AM
Dilbones's Avatar
Old Dec 7, 2017 | 04:39 AM
Dilbones's Avatar
Thanks bud. Gonna try and look at potential grounding issues as a friend of mine said sporadic behavior like this can be caused by forgetting to attach one or two ground wires. Then I'll check power harness to alternator.
Old Dec 7, 2017 | 08:18 AM
Dilbones's Avatar
Also this isn't going to be my track car lol. I'm probably going to daily it and enjoy the MPGs.
ecollinscona
Oct 23, 2014 12:39 AM
KianIntegra
Jun 21, 2011 03:42 PM
racereaper7
Jan 22, 2008 04:37 PM
rehab_this
Oct 18, 2005 07:12 PM
