Engine Swap Pouring Smoke
Old Dec 3, 2017 | 02:26 PM
MastaFlyMason's Avatar
Default Engine Swap Pouring Smoke
So I put a B16a into my CRX and I'm getting TONS of smoke from the exhaust. When I first started it there was no coolant and it was smoking so I'm assuming it's not coolant. I pulled the spark plugs and noticed there was oil sitting on top of the pistons. Engine was supposed to be a fresh rebuild but I got it on a FB group so who knows. I took the oil pan off and it did have SRP pistons and Eagle rods like he told me it did. The compression test was good (around 220psi per cyl). I ran it for 5 or 10 minutes and the smoke never cleared up. Could it be a PCV issue? Or something somehow routed wrong? What would be my best course of action? Thanks all!
Old Dec 3, 2017 | 02:47 PM
2x0's Avatar
2x0
10 Year Member
Default Re: Engine Swap Pouring Smoke
What color of smoke?
White = coolant
Black = unburnt fuel
Bluish/black = oil
Also the smell should tell you whether it’s fuel or oil.
What color were the spark plugs? Post pics.
Old Dec 3, 2017 | 02:51 PM
White = coolant
Bluish/black = oil
I don't think it was coolant, I would say either black or blue but I can't say for sure. No check engine light so I don't think it was misfiring. I'm running the stock injectors from my CRX HF so I didn't have to bypass the resistor box but they're 240cc so I don't think they should be a problem. Running a custom tune on a chipped ECU but I swapped out the ECU for a B18a ECU just to see if it was an overfueling issue and it didn't change anything.
Old Dec 3, 2017 | 07:43 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Fresh rebuild and chromoly rings will smoke for quite some time before the rings seat.
I wouldn't think like no rings at all though.
The block might need a tear down to verify proper ring install and hone job etc.
The other question would be does the head have valve seals in place?
honshu
Jun 9, 2012 10:36 AM
tunerauti
Jun 6, 2008 12:26 PM
KustomCrx
Aug 26, 2004 11:16 PM
egracer44
23
Oct 3, 2003 06:25 AM
nicksweetlude
Feb 2, 2002 08:32 AM
