Engine Swap Pouring Smoke
So I put a B16a into my CRX and I'm getting TONS of smoke from the exhaust. When I first started it there was no coolant and it was smoking so I'm assuming it's not coolant. I pulled the spark plugs and noticed there was oil sitting on top of the pistons. Engine was supposed to be a fresh rebuild but I got it on a FB group so who knows. I took the oil pan off and it did have SRP pistons and Eagle rods like he told me it did. The compression test was good (around 220psi per cyl). I ran it for 5 or 10 minutes and the smoke never cleared up. Could it be a PCV issue? Or something somehow routed wrong? What would be my best course of action? Thanks all!
Re: Engine Swap Pouring Smoke
What color of smoke?
White = coolant Black = unburnt fuel Bluish/black = oil Also the smell should tell you whether it’s fuel or oil. What color were the spark plugs? Post pics. |
Originally Posted by 2x0
(Post 51496747)
Fresh rebuild and chromoly rings will smoke for quite some time before the rings seat.
I wouldn't think like no rings at all though. The block might need a tear down to verify proper ring install and hone job etc. The other question would be does the head have valve seals in place? |
