Car stays on netural but when let foot off clutch on netural it dies
Old Dec 3, 2017 | 09:37 AM
Bubezzy's Avatar
Default Car stays on netural but when let foot off clutch on netural it dies
90 honda accord lx coupe f22a1
Old Dec 3, 2017 | 03:14 PM
Accordian47's Avatar
10 Year Member
Default Re: Car stays on netural but when let foot off clutch on netural it dies
Could be related to the cruise control system and the clutch safety switch. A malfunction of the cruise control computer unit or the clutch safety switch could cut the ignition. Other possibilities are in the engine control system such as a failed sensor that when the very light load of the transmission in neutral is applied, causes the engine to stall. Try starting the car in neutral with the clutch safety switch unplugged, if you even can get it to start, I forget which way the switch works... see if it changes anything. Also try turning the master cruise control power switch on and off and see if that makes a difference.
ed6inms
Nov 24, 2012 12:43 AM
fryman
Sep 28, 2011 05:47 AM
97grnrs
Mar 7, 2008 05:31 AM
efyou
Oct 9, 2007 01:54 PM
binarypunk
Sep 24, 2007 06:04 PM
