Honda Civic 1992 P/S Return Lines
Old Dec 2, 2017 | 12:07 PM
max9505672's Avatar
Default Honda Civic 1992 P/S Return Lines
Hey!
I want to flush the P/S fluid out of my 1992 Civic Si and I want to do it by disconnecting the return line and flushing it using the pump pressure. So I was expecting only one return line, but there are 2 of them :
And this is the only diagram I could find :
I am wondering what's the difference between line 17 (coming from the rack, then cooler, then reservoir) and line 29 (directly from the rack to the reservoir?
I'm not sure which one to disconnect to flush the system.
Thanks
Old Dec 3, 2017 | 04:39 AM
civic402lx's Avatar
Default Re: Honda Civic 1992 P/S Return Lines
Id say the top. Fluid sucked out the bottom, go through system, put back in through top.
unhook top. Cap off top port. Attach drain tube to unhooked tube. Fill up resevoir. Start car, watch reservoir.
Old Dec 11, 2017 | 07:52 PM
max9505672's Avatar
THanks man!
Any other opinion?
Old Dec 12, 2017 | 07:02 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
I wouldn't start the engine, you will empty the PS fluid reservoir in a second. take the belt off and crank the pump over by hand.
Old Dec 12, 2017 | 07:43 AM
max9505672's Avatar
I have seen this done many times, not a problem. But thanks for the input
the soL that could
Dec 3, 2011 09:31 PM
pityocamptes
Mar 28, 2011 07:22 PM
jdmcrx1
Nov 20, 2006 08:22 AM
concept11253
Jan 29, 2006 10:04 PM
nota-eg
11
Aug 11, 2005 08:06 PM
