crx swaped gsr help!?
Old Nov 30, 2017 | 06:37 PM
reddirthonda's Avatar
Default crx swaped gsr help!?
first post here.. i just recently purchased a 1990 crx si with a gsr swap from HMO. it runs good pretty quick but sometimes it throws a knock sensor code? today it threw it when i was in 4th getting up to highway speeds about 4k and when i was headed home i pulled it out in 2nd gear and then put the clutch in and let the rpms fall and it threw it again? the previous owner told me its a jdm block and they dont have a knock sensor? it has a p72 with hondata s300 v2 running jdm gsr base map. also throwing a code 13. b18c skunk2 intake and throttle body A1 trans stock manifold/header. i also have a high idle problem when i got the car it idled at 1500 put new o rings in the map and the iat and it was around 900 and every day i drive it it seems to get a little higher now its at 1500 again? and a small 100rpm surge have it set at 500 in hondata here is a video of it running..
bobbob770
Apr 24, 2013 08:48 AM
milanoteggy
Jul 13, 2012 10:10 PM
aeenox
13
Jun 18, 2009 07:31 PM
rtnlsltn
Jul 18, 2007 02:08 PM
