Can’t figure out this hose
i have a leak it seems from a hose under my distributor cap to my firewall. It caused my car to over heat a couple times and now I hear a dry whirring sound coming from the spot it’s leaking at.
What dsol said. That is already a third party replacement hose. Removing the distributor will make it much easier to work on that fitting. Before removing the bolts, mark the position so you can put it back with the same timing. Also you probably don't have to disconnect any wires.
big.turbo.daddy
11
May 6, 2014 04:43 PM
a12rnulfo
Sep 26, 2008 07:13 PM
