engin bump
Old Nov 28, 2017 | 09:37 AM
L.T's Avatar
L.T
Default engin bump
2001 Honda accord changed cap rotor and spark plugs and got new battery (maintenance required light is on) some times at a red light or in reverse I fill the engine bump.
Old Nov 28, 2017 | 09:39 AM
L.T's Avatar
L.T
Default Re: engin bump
also when I got a new a new battery my radio has some kind of error code
Old Nov 28, 2017 | 10:06 AM
holmesnmanny's Avatar
did you gap the plugs ?
Old Nov 28, 2017 | 04:57 PM
MAD_MIKE's Avatar
MM Gruppe B
Did the car run fine before the battery change?
How many miles on the engine?
When were the valves last checked/adjusted? Tuneup?
Any CEL codes stored? What are they?
If the car has not had a tuneup in a while then the PCM may need to learn that certain components are worn and it will run rough until it either relearns or sets a code.
Do the '01 cars require a security code to unlock the radio? Earlier cars would just have 'CODE' and you would need a 5 number code to unlock the radio. If you tried the wrong code too many times the radio would then display 'ERROR'. Have to disconnect power or radio memory to reset.
Check for a credit card in your owners manual that has the radio code on it, or check the glovebox for a sticker. There will be two numbers use the top 5 number code is your radio code.
If the radio does not allow you to put in the code then you may need to disconnect power to the car to clear the memory.
If you still are not able to fix the radio, you may have to pull it out, to get the serial number.
Then call Honda of America, update ownership information(if not already done), and then give them the serial number to confirm your radio code.
Old Dec 5, 2017 | 09:41 AM
L.T's Avatar
L.T
my engine codes are po75
p1739
p0505
p1259
p0430
Old Dec 5, 2017 | 09:42 AM
L.T's Avatar
L.T
and iv already fixed the radio thank you tho
bal
Apr 3, 2016 07:12 PM
jetlife
Jun 11, 2014 11:22 PM
Chris Hart
Mar 23, 2013 04:28 PM
ParinoidAndroidX
Feb 21, 2007 01:31 PM
dOubleE_dWeeb
Audio / Security / Video
Nov 12, 2005 11:20 AM
