Suspension & Brakes Theory, alignment, spring rates....
94 Integra ABS DTC-1 - pump motor over-run
Old Nov 26, 2017 | 08:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default 94 Integra ABS DTC-1 - pump motor over-run
After years of my ABS light coming on intermittently (it would come on more or less every other time I started the car), I decided to try replacing the pump and accumulator o-rings. It was tough doing it while the ABS lines were still attached, with the modulator propped up on a board. So I got them replaced and then tried bleeding the ABS system by using a jumper wire between the battery and the ABS pump relay wire. For some reason I had a tough time getting all the air out. I was either getting a ton of bubble in the bleed hose, or the fluid was kind of "frothy". I think I finally got it to come out steady, but I'm not 100% sure. It was really difficult to get fresh fluid into the reservoir without air pockets backing up the fluid in the funnel, and making a mess everywhere.
So after all that I drove the car today. Same damn thing. Same DTC 1 as I've been getting. I checked the troubleshooting procedures in the Helms and checked for continuity between the YEL and BLK wires on the modulator harness, and there was none. According to Helms that means my ABS system is pretty much shot.
I read this thread:
https://honda-tech.com/forums/acura-...o-easy-996524/
and I read this thread showing a "rebuild" of sorts on the pump motor:
https://honda-tech.com/forums/honda-...-pics-2830570/
That's for a Prelude ABS pump, and I'm not sure if I would be able to do anything like that on my 94 ABS pump/modulator.
At this point I'm about ready to throw in the towel and just remove the ABS fuse and the light from the dashboard. To replace the modulator would be at minimum $100 off eBay, and I don't really want to spend that kind of money on this car, when it already needs a timing belt and water pump, and needs all the power steering pump o-rings replaced. Is that pump rebuild procedure even a possibility?
Old Jan 14, 2018 | 12:55 AM
dapmc3's Avatar
Default Re: 94 Integra ABS DTC-1 - pump motor over-run
Wow, good luck man.....?
Old Jan 14, 2018 | 09:07 AM
Caoboy's Avatar
-Intl Steve Krew
Active Streak: 120 Days
Loved
Wouldn't be more advisable/safer to do an actual ABS delete if the ABS isn't going to work?
Old Jan 15, 2018 | 07:10 AM
Community Builder
Why? Brakes still work normally even with ABS not functioning. I don't have the time, money or desire to track down and purchase parts to convert to non-ABS on a car that gets driven to and from work maybe 4,000 miles per year.
Old Jan 15, 2018 | 12:36 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Just a suggestion. Figure there wouldn't be any accidental malfunctions from the abs system if it isn't there.
Old Jan 17, 2018 | 07:57 AM
egsleepercivic's Avatar
Do you know where to get the 40/40 non abs prop valve for the 94-97 that I believe is needed for this, other than a junkyard ?
Old Jun 29, 2018 | 07:04 AM
juniorpeterle's Avatar
Hellow, My car is with same issue. I would like knew if you resolved the alarme. If yes, what you did?
Thank you
GaRn
Jun 11, 2009 07:21 AM
davidluko
Apr 27, 2008 06:36 PM
inline4me
Mar 19, 2007 07:15 AM
momstaxi
Dec 9, 2006 04:21 PM
