1994 prelude with 1998 h23a motor
if you mean h23a vtec:
"Here's a list of what you needed to swap from your old motor to this motor in order to keep it all as if it came in the car factory
-intake manifold
-dizzy
-ignition coil
-oil pump
-crank sensors
-motor harness"
people have used H22A4 ecu and of course you need manual transmission since H23A VTEC is automatic and if SI engine didnt had vtec you have to rewire it
-intake manifold
-dizzy
-ignition coil
-oil pump
-crank sensors
-motor harness"
