B18c5 more compression before adding boost
Old Nov 24, 2017 | 01:34 PM
B18c5Dave's Avatar
Default B18c5 more compression before adding boost
hey guys,
I have 94 LS Integra with a B18c5 swap w/trans ........im putting eagle H beam rods in it before i go boost next summer but i was wondering if i changed pistons would i get more compression? If so what pistons should i use? Also are the stock ITR cams good enough to keep since im going boost in the summer or should i put more aggressive lift cams in it ? Im tuning it for the street not drag so i was wondering what u guys think .........thanks
Old Nov 24, 2017 | 03:25 PM
1HGEJ2's Avatar
Default Re: B18c5 more compression before adding boost
10:1 pistons and go itr cams.
Old Nov 24, 2017 | 09:33 PM
TheShodan's Avatar
Moderator
THAT really does sum it all up. Seriously. Don't do **** else. That's all you need
Old Nov 27, 2017 | 12:10 PM
vtecmaster85's Avatar
^LMAO
jksmith
Mar 24, 2008 02:06 PM
94typeR
May 29, 2007 01:21 PM
WangChung
16
Oct 5, 2003 05:03 PM
trillo
May 24, 2002 01:19 PM
is3oo
May 16, 2002 02:34 AM
