1st gen b16 in eg
Old Nov 11, 2002 | 06:21 PM
hondaeg5's Avatar
Default 1st gen b16 in eg
did search. just making sure what i need. obd1 distributor,injectors,harness. anything else? this will go in my friends 92 vx. which ecu would be best?
TIA.
ahcjar103's Avatar
Default Re: 1st gen b16 in eg (hondaeg5)
i'd get a throttle body with obd1 map sensors for cleanliness sake. otherwise you should be good to go.
Old Nov 11, 2002 | 06:33 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: 1st gen b16 in eg (ahcjar103)
get one of 3 ECU's a P30, an obd 1 P72 , or an obd 1 P28 Rechipped with dohc capabilities..(prefered IMO)
Old Nov 11, 2002 | 06:47 PM
Kataku2K3's Avatar
I agree it makes it a lot cleaner.. I like any **** that has to do with wiring to look perfect... and running a little hose off the throttle body to the MAP just doesn't do it for me... hehe
Old Nov 12, 2002 | 04:21 PM
hondaeg5's Avatar
Default Re: 1st gen b16 in eg (JDMspecEG6)
obd 1 ls throttle body ok?
Old Nov 12, 2002 | 05:26 PM
Katman's Avatar
TIA.
here's a few more items you'll need...
- 4-wire 02 sensor
- thermostat temperature housing w/ integrated thermo-sensor as seen here:
- hydro b-series tranny, unless you're using a hasport hydro-cable kit.
- You can use any of these ecu's to power your engine: a JDM or US OBD1 P30, P61-GSR (B17A ecu), P72-GSR, P08/P28/P29/P70 --> all of which would need to be reprogrammed for DOHC VTEC use.
- as for the MAP sensor, its best to get the newer style (92+) throttlebody w/top mounted MAP sensor...but...you could retain the older vaccum-line style TB. Just make sure you have the right vaccum port going to the firewall mounted MAP sensor as seen in this pic (my fingers are holding up the MAP-vaccum line):
Old Nov 12, 2002 | 05:38 PM
hondaeg5's Avatar
Default Re: 1st gen b16 in eg (Katman)
can i use the ls o2 and harness then just run the vtec,knock sensor wires. where do i get that thermostat temp housing from? my friend currently has the same setup as me but he found a 1st gen longblock for a good price. by the way thanks,youre the MAN! LOL.
Old Nov 12, 2002 | 07:04 PM
Katman's Avatar
if the LS motor is an OBD1 engine (94+) & has a 4-wire 02, yes you can reuse it, and yes you can reuse the engine harness and wire it with vtec and KS wires. I haven't confirmed this myself, but I believe you can use a 92+ D-series or 94+ LS thermo-temp housing on the b16a engine.....you might want to look into this yourself....try using your LS one on the b16a.
good luck
mynameizstitch
Oct 5, 2009 07:05 PM
craigb16a
Engine Management and Tuning
10
Dec 29, 2008 03:27 PM
jewpont
Apr 9, 2008 07:57 PM
Arbiter
Sep 23, 2007 09:38 PM
