98 Honda Civic CVT to Manual
Old Nov 22, 2017 | 11:30 AM
kimanibroderick's Avatar
Icon4 98 Honda Civic CVT to Manual
I have recently done an auto to manual swap on my 1998 Honda Civic hatchback. It came with the cvt transmission. I have not swapped out the auto ecu, the car has started and is running but it runs very rough and the check engine light and flashing "d' indicator light is on.Also, it has a slight surge and is trottling a bit high. How do I fix this? Does anyone know what modification I can do to the ecu to solve this problem?
Old Nov 22, 2017 | 02:31 PM
mk378's Avatar
Default Re: 98 Honda Civic CVT to Manual
Whenever the battery has been disconnected, it is normal to run rough / uneven for several minutes until the ECU re-calibrates.
You will have to swap the ECU to get rid of transmission codes. OBDII ECU's don't have jumper mods like OBD1 do.
janek
Aug 12, 2011 12:07 PM
tturbocivic0618
13
Apr 15, 2008 01:40 PM
ballified
Oct 13, 2007 02:34 PM
h22honda89
10
Aug 19, 2007 02:40 PM
0618turbocivic
Nov 11, 2006 06:49 PM
